- Mon Sep 11, 2017 12:54 pm
#7692
Well guys – again I must rebuild my 1996 535cc – after a total of ~16000kms. After a few hundred kms from the last work of trouble-free riding, cruising at up to 4000rpm, I was idling in a traffic queue, in neutral, when there was a series of metal crunches and the engine stopped. Jammed and damned.
When I tried to remove the left side spark plug (it’s twin-plugged) it wouldn’t unscrew. That’s when I knew it was bad.
When I got the other plug out and eventually removed the left side one, I found it had a perfect imprint of a valve head in it. Since I cannot now copy the image tag to place here, please see my Chrisd200 account at photobucket (the Broken Valve library). Here I am trying IMGBB as suggested by Exile.
The view through the plughole showed a bent valve lying on some unfamiliar texted aluminium, perhaps the inside the piston, which could be much more expensive.
Time for a rebuild, methinks.
NB: there was no warning to this break. NB too; This valve and the collets were the only indian parts remaining in the motor (apart from the flywheels). Well, I guess the valve was due to fail soon, based on the distances I’ve heard others have trouble, so I guess I only have myself to blame. I’ll keep you posted on the progress.
Cheers, ChrisD
PS: I shall follow this up as I summon the courage to remove the head.
. The view through the plughole showed a bent valve lying on some unfamiliar texted aluminium, perhaps the inside the piston, which could be much more expensive.
Cheers, ChrisD
