- Wed Sep 06, 2017 7:59 am
#70596
Have you mounted your new tyre with the pink spot opposite the valve ?. When tyres are manufactured the makers mark the heavy side of the tyre with a pink spot, this should be opposite the valve, it does sound like a wheel balance problem. On my bullet I have a carrier with a two helmet box, if there is a heavy weight in this box it does affect front end handling at low speeds, so if you have put any extras on rear of bike this will upset the balance of the bike and may cause poor handling on the front end.
