- Thu Jul 05, 2012 4:44 pm
#760
I'm currently quite pleased.
Stripped and cleaned my carb last night, the bits that fitted my wifes little ultrasonic cleaner went in there and the bits the didn't were attacked with toothbrush and muc off.-------------
(On a little side note, i'm massively underwhelmed by Muc off, bought 2 5L containers on the strength of reviews and people enthusing about how effortlessly dirt shies away from it, it's OK, certainly nowhere near the brilliant people suggest unless i'm doing something wrong with it?)-----------------
Re-assembled that with 25 pilot and 90 main jet as it's all going back stock, airbox and exhaust etc, plus the main in there was way too big even for an open carb and exhaust, it had a 110 in there.
Had to make a seal for the cap where the cable passes through and attaches to the piston, used an old inner tube for this and nabbed a fibre washer from the decoke set for the choke plunger knob, that had been 'sealed' with PTFE tape, does the job for most things but has a habit of getting everywhere, so carb refitted with new gaskets and I took off the battery box and breather catch can to give them and the surrounding frame and wires a clean, refitted everything with the one exception of the (square dummy) airbox to carb rubber as it has mysteriously disappeared, I don't know if it's me forgetting where I put it or my wee boy who, in the fashion of wee boys, often sees things that look cool and would fit his Ninja sword / Ben10 omnitrix / etc etc.
Fitted the battery, which, refilled with acid and on the optimate, (disconnected last night reading 12.98v and checked this morning, still 12.98v), seems to be holding charge ok.
Took a fresh NGK plug, did a quick test earthed to the cylinder head, seemed to have a bit of a spark, nothing earth shattering but there, thought i'll give it a go, plug in, nipped up, everything checked, connected and tightened, choke on, fuel on, ignition on, ease over compression, one hefty kick and it fired up, FIRST TIME!
I was thoroughly pleased.
Need to find the missing carb boot as it's currently sucking in way too much air on an open carb for the setup but I can now focus on setting the carb with the colourtune, re-torquing the head nuts, checking it over and then arranging an MOT, then a general service, oil, filter plus tyres tubes etc
The plan was to grab a coffee then have a quick fettle with the multimeter and check the alternator output, recheck the charging via the reg/rec, refit the new reg/rec if it's still not right and so on but like those wussy tennis players I had to give way to the sudden torrential downpour. So rain stopped play but i'm pleased it's running all the same.
