- Sun Aug 20, 2017 7:36 pm
#7630
On my 1999 4 speed Enfield 500cc the kick start return spring has jumped out of the little hole in the kickstart shaft. When I put it back in it doesn't seem to stay in the hole very well, I'm wondering if a bit might have snapped of the end?
There is about 5mm of length that goes into the hole, does that sound about right and it's a common problem that is jumps out? The bend is not far of 90deg is that okay? if it was more acute it might grip the hole better?
