- Wed Aug 16, 2017 2:32 pm
#7619
Can anyone advise me how to seal the primary chain case cover on my 1955 500 Twin. I've just finished the restoration and partial engine re-build. It was non running when I got it so don't know what the history is. I cannot stop the oil leak (or even staunch it to an acceptable level). I've done the following all to no avail:
1. New rubber gasket, new stud and central nut and washer. Helicoiled the thread on the engine casing.
2. I've torqued the nut to 12 and then 14 ft lbs
3. I'm using AT fluid oil as recommended.
On my second run out after 6 gentle miles I had lost about 100 mill of oil.
4. On an earlier attempt to seal it I used silicone instant gasket to support the rubber seal. The rim is not distorted as far as I can tell (by placing it on a machine bed - it doesn't rock). I haven't yet tried to use the silicone with the extra torque.
Any suggestions would be much appreciated.
