Changing Bullet 500 gearbox to 5 speed
Posted: Fri Aug 11, 2017 6:00 pm
by flactem
Has anyone experience of changing the 4 speed gearbox to 5 speed?
The 2003 machine has done 4,140 miles so is still very useable - is there a market for exchange, or sale, towards the cost of a new 5 speed box? Any information or thoughts would be appreciated.
Posted: Fri Aug 11, 2017 10:25 pm
by binary
I put a 5 speed gearbox on my 1964 Royal Enfield. I bought a second hand left shift 5 speed gearbox off Hitchcock's. I then put a Hitchcock's right hand conversion kit on it. I fitted it up and it has made a brilliant difference to my motorcycle. I love to ride my bike now that the old 4 speed gearbox has gone. I changed the gearbox with out having to take the engine out of the frame. There was nothing to have to alter. The 5 speed just slips in with out any problem as it is slightly smaller than the 4 speed. To pull the old box out you just completely take out the 4 studs that hold the gearbox to the engine and then the gearbox will slip out the right side of the frame. The new box just slips in the same way and then you just put the studs back in again. From my experience of doing this conversion
I lost money by buying a second hand left shift gearbox and then having to convert it to a right hand shift. My advice is to buy the right hand shift 5 speed gearbox from Hitchcock's part number 90110 or 90111. With this box you will get the whole gearbox and everything that you will need to do the conversion. I lost money because I had to buy all this stuff seperatly. Buy the full gearbox and it will come with the fitting kit and then it is just a strait forward conversion. If you go ahead with the 5 speed gearbox and need some help I will give you my email address and you can contact me through that.
Posted: Fri Aug 11, 2017 11:34 pm
Hi FLACTEM------I've not actually changed any boxes as such but I am now on my fourth 500cc Bullet.........No1 was a "Bullet '65" with a 5-speed box as standard....Nos. 2 and 3 were normal (?) Albion 4-speed with neutral pre-select, and No.4 is again a "Bullet '65" with 5-speed box as standard.............So you can see I've had a fair crack at both types and I can tell you without any hesitation whatsoever}---- DO IT !!!--DO IT !!----DO IT !!......Apart from a box that has a more traditional design of innards ( Cam plate--sliding dogs---oil lube ) you'll also get 5 well thought-out ratios that completely do away with that "Grand Canyon" gap between 3rd and top....TIP}--- You might find that re-locating the kick-starter lever further round anti-clockwise by 3 or 4 splines will help you put your right foot on the road without catching said lever on your boot when you stop.....plus it'll help with kick-starting as well....As BINARY says, my bike also is a joy to ride with 5 speeds.....As to the old Albion box ??....Donate it to Sammy Miller's or The Nat. Bike Museum in Brum !!
Posted: Fri Aug 11, 2017 11:54 pm
by Tim NZ
I have fitted a couple, and for what it was worth i'm just as happy with the close-ratio 4 speed box.
The 5 speed item is a better design 'box and is more efficient, but the change over is costly and a lot of work. If you do decide to change, make certain to fit the latter improved 'stirrup' clutch cable connecting arm. The original 5sp fixed lever clutch operating arm snaps nipples off cables.
Posted: Sat Aug 12, 2017 12:19 am
Hi TIM NZ---- what close ratio 4-speed box is this then ???....new one to me.., Yes, you're quite right about the potential cost BUT they do come up for grabs now and then.....I bought mine from our hosts from their "Special offers" link and they have been on E-Bay from time to time..Apparently there are other Enfield Sellers like our hosts -- but one might be a bit "Pricey" ......Agreed about that operating arm.. I must get this new bike of mine checked out...I have a new cable to be fitted so maybe a bit of "Spare Time" ( whatever that may be ??) next week ??
Posted: Sat Aug 12, 2017 4:20 am
by binary
If you buy a "new" complete 5 speed gearbox from Hitchcock's the later improved stirrup clutch cable operating arm is already installed. The 'second hand' gearbox that I bought off Hitchcock's still had the old one and when I told them they sent me the newer designed one free of charge. It makes the clutch much lighter to operate and will not break the nipples off. The part that we are talking about is inside the gearbox cover. The clutch cable nipple fits into the stirrup and when you pull the clutch lever it moves a ball and ramp arrangment to push on the clutch rod which then pushes the clutch plates apart. It is just a simple thing but it works good. I found this clutch arrangment much lighter to operate than the old 4 speed. I did not find the 5 speed gearbox expensive. I am on the old age pension and I was able to buy one and have it shipped half way around the world to where I live. It was either this or I was going to sell my Royal Enfield. Now with the 5 speed I will never have to sell it. It changes gear just as good as any Japanese motorcycle and I have owned a few of them in my time.
Posted: Sat Aug 12, 2017 9:12 am
by ed.lazda
I put a 5-speed gearbox on my wife's Bullet 350 and she tells me it has completely transformed the bike and her confidence.
Posted: Sat Aug 12, 2017 10:30 am
by mauri
whith this link you can find the parts needed + picture about the howe and what to do to get the conversion done.
and as im not magician that can make some parts of the 4 speed(which simply won’t fit) to work whit the 5 speed, therefore a made my answers in the thread as complete as a could.
Posted: Sat Aug 12, 2017 1:44 pm
by flactem
My thanks to all concerned for the information. A lot to digest and it will take a while before I can move on. Many thanks.
Posted: Sat Aug 12, 2017 5:02 pm
by Felix
Many Bulleteers in the USA pay over $300 just for a 4sp RH shift conversion kit.
Yeah, there's a market over here.
