- Sat Aug 05, 2017 3:45 pm
#7588
My Lightning 535 is fitted with a 95 pitch Elite drive chain which has lots of side play and is beginning to lift off the rear sprocket. The rear brake anchor looks to be almost at its most forward position (I haven't removed the nut and washer to check exactly how far forward). I was puzzled as to why a seemingly worn chain had so much adjustment left until I realised the bike is fitted with an eighteen tooth front sprocket. Has anyone had experience of fitting a new chain with an 18T front sprocket? Is it better to stick with 95 pitch or would 96 pitch be OK with the bigger sprocket?
