- Fri Aug 04, 2017 1:48 am
#7585
My bullet smoked like a chimney on startup the other day but then ran fine after a few minutes. Wet sumping, I assumed as I never bother to leave it at TDC at night and it had not run for a few days. So next night I left it at TDC and in the morning it smoked again but not much. So, not wet sumping I assumed. Took the timing cover off and the rubber seal in the oil pump worm just fell out so oil would have easily leaked round it and into the timing chamber. My mate had a new rubber seal which is a tighter fit so I have fitted that. Also I slit my old one to make a 4mm extension of it so it would compress better in the nut. When I tightened the quill bolt I could feel it squeezing up a bit so I think it should be more effective now and I will report back in the morning. I notice our hosts sell a worm nut with a neoprene seal already stuck in so I may try that. Can anyone tell me if a leakage around this seal will cause smoking and symptoms of wet sumping. Also would any harm have been done regarding feeding oil to the right places.
