- Wed Aug 02, 2017 4:43 pm
#7579
Hi everybody I need some help is there somewhere I can get a wiring diagram to wire the horn/dip switch (lu/31563) into my 2001 bullet 500? I have it wired in but my lights are pulsing,, there is a wire left over from my previous cluster for the third momentary position not being used now. my old LH cluster had hi beam low beam and a momentary flasher all the way slid up and no headlight off if that helps,, I used the universal indicator switch for my blinkers (92032a) that works great
