- Tue Jul 18, 2017 10:28 am
#7522
Hi all, back again. Sorry not been on here for a while, too many projects, the Enfield got pushed to the back and covered with junk ! I have now dug her out, and intend to try and get this project finished. To recap, it's a '53 (ish) Redditch Bullet, built up as a trials bike. Though somewhat half-hearted as the footpegs are in the standard position. Previous owner apparently died before finishing the bike, lots of new bits, but badly assembled. The front (engine) sprocket if you remember does not fit the primary chain, very weird, so I am ordering a new sprocket and chain from our hosts.
The gearbox sprocket is a 15 tooth (one smaller than standard) and the rear wheel, a 38.
The clutch has 56 teeth.
I am looking to stick with gearing that is not too low for road use, should I go with the 25 tooth engine sprocket that is standard, (bearing in mind the gearbox sprocket is already one tooth smaller than standard), or would the 22 tooth gearbox sprocket be ok ? That's the next smaller size available. It's almost certainly not going to be low enough for serious trials use, but I intend to get the bike running and road registered before I decide if I shall use it for road or off-road. I don't want to end up paying for a sprocket that's neither low enough for off road, and too low for the road.
Cheers, Tony.
ps - Mark, you going to be at Kempton this week ? We shall be in the usual place.
Cheers, Tony.
