Oxford Blanket problems
Posted: Mon Jul 03, 2017 2:30 pm
by Graham43
Anyone found that the Oxford Blanket Multi-purpose Ant-slip Mat when used under a lightweight map holder sticks to your petrol tank leaving behind lumps of the plastic/rubber it is made from. I used one on my spray painted fuel tank and the blanket stuck to it and is a begger to remove. I am in 'discussion' with Oxford who, after giving them a lot of photos and information, suggested it can be removed with water at 48 C and a micro porous cloth - it cant. So far white spirit takes it off with a layer of paint. Anyone had similar problems?
Posted: Mon Jul 03, 2017 4:09 pm
How long had the tank been sprayed?
Posted: Tue Jul 04, 2017 7:23 am
by Graham43
Two or three months and the bike used many times since re spray.
Posted: Tue Jul 04, 2017 9:10 am
Some plastics and paints react with one another. Usually a lacquer coat over the paint protects against this. I think you have been unlucky and frankly unlikely to get anywhere with Oxford, they'll simply say they can't be responsible for how you use their product.
Posted: Fri Jul 07, 2017 7:13 am
by Graham43
Just for the record Mark M - Oxford have paid compensation with their other products which suits me.
Posted: Fri Jul 07, 2017 8:18 am
Thanks Graham, for reporting good customer service! I have used Oxford products over the years and always been happy with them, (good products at a fair price) but I was thinking there's obviously a limit to what they can cover. Good luck,
Posted: Fri Jul 07, 2017 8:54 am
by Valsp
White spirit shouldn't normally remove paint from a tank
What type of paint was it sprayed with?
Posted: Fri Jul 07, 2017 9:04 am
by Revband
If white spirit removes the paint it won't have much chance of resisting modern petrol. It does sound like it is a paint fault rather than the Oxford blanket?.
