- Sun Jun 11, 2017 1:27 am
#7396
I have recently installed Hitchcock's EFI carburettor conversion on my 2015 B5. Ever since new the bike had been running rich and the spark plug was always fouled with carbon. It didn't matter what spark plug was used, hotter, cooler or iridium and I wanted the ability to adjust the tuning - and the carby option is less expensive than a Power Commander.
The retrofit was reasonably straightforward and I added an inline fuel filter to the Hitchcock's kit. The bike started first turn and has been running well since and most of the time seems better than with the EFI. I am however, experiencing a couple of problems . Problem 1: most of the time the idling is stable and regular and much more consistent than with the EFI, however, occasionally, and usually at the most inconvenient time, the engine hesitates and stops. It will start again but takes a little time and then seems to run OK again. Problem 2 : There is some banging (backfiring) in the exhaust, especially when changing down when coming to a bend or a stop i.e. when the throttle is closed or nearly closed. There was some of this with the EFI but not quite as much. AMAL's literature says this can be due to either a lean pilot mixture, or, a rich pilot mixture and an exhaust air leak.
The retrofit carby is an AMAL Mk 1 concentric 932/300 with a main jet of 220, needle jet of 106 and a throttle with a # 3 cutaway.
I'd be grateful for any suggestions.
