Page 1 of 4
Sprag woes ! my turn !
Posted: Sat Jun 30, 2012 8:32 pm
by Ian M Brown
Yes folks my much defended sprag has gone awol, and while I think I know all the procedure to replace it, and have ordered all relevant tools, I do recall on here a while ago, some info regarding a better quality component (Borg-Warner transmission ??) could someone remind me of this ?? many thanks
Posted: Sat Jun 30, 2012 9:43 pm
Hi IAN }------------ If you replace it (£50-60 ??) it will only go again at some time. That "Better quality component " may well be your KICK STARTER !! Why not save a whole pile of dosh---increase your street cred standing amongst the "Old Boys" and get some exercise into the bargain ??? So not only will you be riding the experience, you'll actually be living it as well. Steroids & Chips, works for me !!
Posted: Sat Jun 30, 2012 10:37 pm
Ian,
From what I know the Borg Warner sprag isn't any better, just cheaper
Posted: Sun Jul 01, 2012 9:23 am
by JOHNNY SINGLES
Ian, how did it fail, what did you do or did not do, a sprag does just not fail without a reason.
Posted: Sun Jul 01, 2012 9:29 am
Johnny, you're quite right, there must be a reason. It seems to me that the reason is a very poor design.
Posted: Sun Jul 01, 2012 10:05 am
by JOHNNY SINGLES
Pete, I have had 8 electric start 500 bullets, my sprags have never failed.
Posted: Sun Jul 01, 2012 10:12 am
by Jack
Ian,i've seen a supposed better sprag,i think it was on ebay.Supposed less of the actual sprags and they were much beefier,and the ring was stronger.Unfortunately i can't find them just now.I should have bought one myself,then at the time.The Borg-warner sprags as Norm says are the same as the RE ones,so will have a limited lifespan too.
Posted: Sun Jul 01, 2012 10:19 am
by Jack
Here's some reasons,points ign deteriates and all it takes is a phutt!!!,it's just one of those things with singles,very hard to have them 100% perfect.
Long stroke heavy flywheel put's extra strain on sprag.
Standard sprag could be made much better/stronger.
Posted: Sun Jul 01, 2012 6:15 pm
by Ian M Brown
Alan, I know where youre coming from, and, sad to tell I do often kick it over if there's an audience, I simply would miss the convenience of the electric foot for those times it stalls at the lights, or I'm just being lazy.
Johnny & Pete, its simply a bad design, compounded by some poor components /tolerances, some are lucky some not, I've had horrible grinding noises a thousand times from it due to a backfire or fail to start, I am likely fortunate it's lasted this long.
So, I will make the best of the opportunity and change my final drive sprocket at the same time, may even do the R/H shift conversion while I'm at it !
Posted: Sun Jul 01, 2012 7:18 pm
by Alex.
I'm always interested/worried hearing about sprags - and end up wondering when mine will go! Just out of interest what model and mileage have you?
