- Sat Jun 30, 2012 4:47 pm
#729
Bullet 350 with Amal concenric mark 1. I have just re-jetted the carb from a 180 main jet to a 200 to richen things up a bit. I also replaced the standard B7HS plug with the iridium B7HIX to see what difference it might make to starting.
Whilst the B7HS was a nice "coffee" colour after a run out, the iridium plug appeared almost exactly the same colour after a run out, as it did when I first fitted it! i.e. the white inner is still white.
Any chance it might still be running lean, or do iridium plugs tend to run "hotter" anyway?
Any comments appreciated. As usual, I'm concerned about valve burn-out if it's running too lean.
