Gearbox sprocket nut
Posted: Sat May 20, 2017 1:51 pm
by Tom Tuc
Can anyone help? I am trying to remove the gearbox sprocket on my 2008 EFI and the nut that holds it is 46mm. Does anyone know if this is a LH or RH thread? It is a thin nut and very tight, I don't want to force it the wrong way. I am assuming it is standard thread but I have been caught out in the past. The workshop manual doesn't help much.
Thanks in advance.
Tom
Posted: Sat May 20, 2017 3:08 pm
by hagis
From memory the thread is conventional IE anti clockwise, When I changed my front sprocket I left the chain on and with the bike in gear, locked the back wheel to undo the nut, it all came apart very easily.
Posted: Sat May 20, 2017 3:17 pm
by Tom Tuc
Thanks Hagis, I will put a little more umph to it. I have the block out as I am stripping the whole thing so can't use the same technique as you.
Posted: Sat May 20, 2017 4:19 pm
by Beezabryan
Whack the spanner with a big hammer, brute force & pig ignorance often works ;)
Posted: Sat May 20, 2017 6:10 pm
by Chris [Stockport]
Just before you try Beezabryan's idea, have a look at this picture. The LHT sometimes have a groove, as shown.
Posted: Sun May 21, 2017 8:44 am
by ed.lazda
Definitely normal thread (anticlockwise to loosen). I've occasionally used a length of old exhaust pipe over a big spanner for extra leverage (e.g. for exhaust nuts).
Posted: Mon May 22, 2017 10:19 pm
by WDCO42
Hello Tom, in a general matter, all the nuts that are on moving parts (engine crankshaft, gearbox shafts and so) are right thread on the left side on the bike, and left thread on the right one. Hope it will help you. Claude
Posted: Tue May 23, 2017 6:19 am
by Andy M
Air or electric torque gun is the best bet. I got mine for exactly this job and never looked back. Normal thread as far as I recall.
Andy
Posted: Sun Jun 04, 2017 2:15 pm
by Tom Tuc
Thanks for all your replies. As it turned out the brute force option worked! Because the nut is so thin it was difficult to get a firm purchase so needs two of us. Once I had cracked it came off easily. Thanks again, Tom
Posted: Sun Jun 04, 2017 2:31 pm
by hagis
The EFI manual says, NOTE care to be taken while fixing FD sprocket, direction circular groove index mark facing outwards, Assemble lock washer and nut toque to 7.5KG-M. Lock the tab over the FD sprocket nut.
