- Sun May 07, 2017 3:38 pm
#7315
Hi all, following on from my post a few weeks ago about the rear wheel rubbing on the chain guard i decided to investigate further.
The wheel is correctly aligned but appears to be 5-10mm too far to the right in its entirety. It is far closer to the RHS swinging arm than the left (i know they are never exact) and on looking at the wheel from the back it is on the RHS of the mudguard by the same amount. So much so that on full travel the RHS of the tyre is rubbing on the fixing nuts on the inside of the mudguard. I have had the wheel off again and checked the spacers. Here is what i have ... from the LHS,the spindle goes through the adjuster then large spacer, the spacer butts up against a smaller top hat spacer that sits inside the grease cover on the bearing and butts up against the bearing. Spindle goes through the hub, no other spacer inside between the wheel and the cush drive mechanism. There is then a washer between the hub cover and the swinging arm then the big 30 mm nut, then the castellated nut to tighten the spindle. So in short only 2 loose spacers on the whole spindle. Our hosts parts diagram does not seem to show the top hat spacer, but if it wasn't there the big spacer would crush the grease seal i assume. Any guidance from the great sages would be appreciated.
