EFI battery?
Posted: Thu May 04, 2017 7:17 pm
by Richy2spanners
Hi Guys, can't believe I'm here,cap in hand, 2 days in a row. Tried to start bike today(2009) only got electric start. All the symptoms of a flat battery. Hardly turning the engine over then nothing. I still get lights to work, even main beam. So I took the battery out and checked voltage which reads 12v. So do you think it is battery or something else?
EFI battery?
Posted: Thu May 04, 2017 10:15 pm
Is that the original battery still, or at least a few years old? Could be on its way out, though still not completely failed if the lights still work. The E/S needs a healthy battery for the E/S to crank the engine over, this was certainly the case with my Electra-X which used the same starter motor as the EFI models and was also struggling, though at least I could still kick start it. Fitting a Motobat 14AH AGM battery brought the flagging E/S back to life, our hosts may stock an equivalent. A.
EFI battery?
Posted: Thu May 04, 2017 11:43 pm
by Leon Novello
The easiest way to find out, is to charge the battery. Or take it to an Auto electrician; they usually test a battery for no charge; I mean free.
EFI battery?
Posted: Fri May 05, 2017 7:43 pm
by fidgad
My two_year old original lead acid bike battery was weak and unreliable sometimes needing to kickstart the bike. Replaced it today with a decent gel battery. Such a pleasure thumbing the starter button and bike leaping into life.
EFI battery?
Posted: Fri May 05, 2017 9:10 pm
by rog
Certainly sounds like a duff battery. However,if the lights work I suspect you should be able to kick start the the bike. My Efi is 6 years old and I've changed the battery twice. On each occasion I had the same symptoms, ie engine reluctant to turn over. Both times it still kick started easily.
EFI battery?
Posted: Fri May 05, 2017 9:49 pm
You need to check the battery voltage under load. If the voltage drops off when you put a load on it it's new battery time.
EFI battery?
Posted: Sun May 07, 2017 11:02 am
by zonggong
You may also want to try checking the interlock switch on the clutch. Mine gives occasional trouble resulting in the symptoms you describe.
EFI battery?
Posted: Mon May 08, 2017 5:30 pm
by Richy2spanners
Thanks Gents, new gel battery and I'm away again.
