Kick starting with warm engine
Posted: Thu May 04, 2017 12:49 pm
by NicoV
My Jan. 99 Bullet starts reasonably well when cold. However, when the engine is warm I have much more trouble starting it. I always succeed, but it takes much many kicks.... What can be the reason ?
My Bullet has the standard Mickarb carburettor and the Boyer electronic ignition.
Posted: Thu May 04, 2017 12:56 pm
by Chris [Stockport]
Mine needs the throttle holding a bit more open when starting warm, then all's well.
Maybe?
Good luck, Chris
Posted: Thu May 04, 2017 5:47 pm
by Reg
Hi Nick, I had the same problem which seemed to coincide with a change of fuel. Having always used regular petrol I decided to treat my bullet with "super". The bike appeared to run a little better (all in the mind with hindsight) but was much harder to start from warm. Since going back to regular no problem with warm starting. Hope this helps.
Posted: Fri May 19, 2017 10:31 am
by NicoV
Thanks to everyone for the reply.
I noticed a clear improvement when starting with the throttle more open.
