- Tue Apr 11, 2017 10:36 am
#7243
Hi All,
I imagine this subject has been done to death so forgive me if this is repeated but your help and knowledge would be greatly appreciated.
I am re-assembling a G2 350 1955 engine and am at the point of installing the crank and resealing the crankcases. The problem I have is with both thrust washers included in the assembly the crank is fouled and cannot move.
The timing side bush and roller bearing have all gone back in as expected - the roller bearing sits flush with inside of the casing.
The drive side bearings and spacer again are as expected.
The thrust washers are new from our hosts.
Any ideas / pointers gratefully received.
Thanks All.
Thanks All.
