How to remove powder coating from bolt holes etc?
Posted: Tue Jun 26, 2012 3:06 pm
Hello again!
I have a frame that previous owner has had powder coated. Powder coating would not be my first choice for a frame, but since the job is done I will probably live with that. However, there are two things that I must attend to, before I can assemble the bike: .-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-
1. The powder coating is a little "too complete", i.e. most bolt holes and especially the large holes for the rear plunger springing "inner tubes" are also filled with the stuff and consequently too small. I have foun that it is rather hard work removing this...... How to do it as good as possible, without damaging the coating outside the holes (or damaging the holes themselves)? .-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-
2. Fortunately the seats for the steering bearings are not powder coated. However, here the coating is flaking off a little on the edge outside the bearings. How do I repair this? Hot air gun to "weld" the coating in place again? Superglue under the loose edges of the coating? .-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-
3. Or should I get the whole frame stripped and properly repainted with "real paint", primer etc. etc., like it most likely was done at the factory "anno dazumal" in 1938?
Thankful for all good advice or thoughts about this!
Regards, Anders F. R.
