- Sun Mar 05, 2017 11:14 am
#7117
Hello All,
I recently bought my first classic bike (1953 Redditch Model G) and I'm just starting to put together a list of parts needed to hopefully get it roadworthy in time for the summer. Before I dive too far in and start stripping things down further than I need to I just wanted to ask for some advice about the kick start lever.
When the engine isn't running the kick start lever sits in its normal position but once the engine has been started it remains in the rear most position. If you lift the lever back up to where it should be then it flops backwards as if a return spring isn't being applied.
If it helps in any way... The lever didn't do this when I first bought the bike, it only started when I removed the foot rests and the foot rest shaft to start looking at and oil leak from the chain cover. I don't know if this has any relevance but it's the only thing that I've touched so far.
Any suggestions as to how to resolve this would be much appreciated.
