- Fri Mar 03, 2017 4:33 pm
#7114
My 2005 Bullet Sixty-5 has a habit of stalling while idling - usually just as the lights go green! It has a high level trials exhaust with baffle tube and a VM28 Mikarb with a pancake air filter, 2.5 slide, 125 main jet, P2 needle on middle slot and 30 pilot jet. The carb to head rubber is new. The plug is NGK B8ES gapped to 20 thou and the coil and HT lead are new. It also has a Boyer ignition with the idle timing set using a strobe. I have stripped and cleaned the carb and tried setting the idle as per the recommended procedure, but adjusting the idle jet has very little effect. Sometimes it will idle for ages and other times not, the stalling being random. It also seems worse when the engine is cold. Is it possible I have the wrong jet/needle set up or is there anything else I might have missed ?
All suggestions welcome
Many thanks
Many thanks
