Is this for Royal Enfield
Posted: Sat Feb 18, 2017 12:57 pm
by enfield_trials
Hi Guys
I got the below for Royal enfield trials project.
not sure it is for royal enfield or some other bike .. can i use it with bullet forks ?
Thanks & Regards
Posted: Sat Feb 18, 2017 12:59 pm
by enfield_trials
I apologize posted the photo twice , wanted to paste this one
Regards
Posted: Sat Feb 18, 2017 1:16 pm
by Bullet Whisperer
I think that might be from an Ariel.
Posted: Sat Feb 18, 2017 1:56 pm
I agree, it has an early 1950's Ariel tele fork look about it (they swapped to nacelle headlamps later on).
http://www.shannons.com.au/library/imag ... rcycle.jpg
Can you use it on a Bullet? Hmmm. Never seen one fitted, even if it is outwardly similar to the Enfield item (see our hosts' versin in the accessory catalogue). IF everything lines up correctly with the RE bottom yoke, IF the holes for the fork legs are the right diameter, 1 3/8" with the right thread, if they are the right distance apart, if the steering stem is long enough, IF the stem hole is the right distance from the distance from the fork legs, IF the steering head bearings are compatible, etc, etc...
It would have been a good idea to find out what it was before you parted with the £££ unless you bought it cheaply, and with a chronometric speedometer sitting in it I suspect it wasn't cheap!
Never mind, the speedometer itself is well worth having and getting refurbished, and if the Ariel top yoke doesn't fit the RE forks and/or bottom yoke you can always sell it on to an Ariel owner and put the money towards the actual RE item. Be careful if you are tempted by an Indian copy, some of the machining can be a bit off, which is why Mr H. no longer sells them.
Posted: Sat Feb 18, 2017 5:31 pm
Yes Ariel as the others said. If you want a suitable top yoke for a Trials Enfield I might be able to help?
Posted: Sat Feb 18, 2017 6:50 pm
by enfield_trials
Thanks Bullet Whisperer , Adrian , Mark M
____________________________________________________
Guys are spot on. i got this with royal enfield parts lot.
@Adrian i like you ideas. may be it better to sell this one and get proper one.
@Mark M ,
Yes i will appreciate if could help . datarector AT yahoo.com
Posted: Sun Feb 19, 2017 7:55 am
ET I emailed you but it bounced back. Check your email address please?
REGards, Mark
Posted: Sun Feb 19, 2017 11:55 am
by enfield_trials
Sorry typo problem datareactor AT yahoo.com
thanks
