Fork Oil : help please
Posted: Sun Dec 11, 2016 2:21 pm
by Graham43
Hi
As a general rule would I be correct to use 'thinner' oil to 'soften' my front forks? Currently using 10W so would using 5W do the job. Or are significant changes only made by a 'softer/weaker' spring? To own up this is not for my Electra but for my BSA Bantam trail bike I have built using a Yam SR125 engine and Suzuki GN125 forks (for the disc brake and stronger stanchions.). All advice will be appreciated.
Posted: Sun Dec 11, 2016 3:15 pm
Yes, you're right, a thinner oil will give you less damping and so a softer ride. I use ATF in the Bullet which I believe is about sae 7. The Triumph Cub likes 20/50 however.
Posted: Sun Dec 11, 2016 3:47 pm
by Graham43
Thank you PeteF. I did think so but my old brain wasn't sure.
