- Thu Dec 08, 2016 2:53 pm
#6920
I decided to replace the aging headlight bulb on my '94 Bullet as it was, to be charitable, week. A direct replacement with a 36W bulb made no discernable difference so I went to my local motor factor and picked up a H4 light unit and bulb. The first problem I ran into was that the bulb connector hit the speedo cable so I "solved" this by bending the bulb blades and wiring them individually. However although there was a huge increase in light output the ammeter went straight to the minus side and stayed there when running.
I was wondering if anyone knew of an LED replacement, either H4 or better yet BPF?. When I did a google search there were a number but most appeared to be from China. Some had a heat sink which would definitely rule out the H4 for me unless there is a shallow light unit available?. I did come across a site which sold some for vintage cars but at £50 I decided to keep looking.
