- Fri Nov 18, 2016 4:06 pm
#6882
Hi all
I know this sounds ridiculous but I want to make sure I follow the best process when changing the oil on my 350 Bullet (2008 reg). I am used to land overs with one sump plug and a screw on oil filter so hence the question. Can someone point me in the right direction please. I would like to install the filter spacer and magnet from the shop here also at the same time. I have read that you should soak the new oil filter in new oil before fitting and different orders for removing sump plugs and now I am not so confident. All help appreciated ! Cheers Ant
