Oil leak - no laughing at the back
Posted: Thu Oct 20, 2016 3:49 pm
Hi. Just bought a 1966 RE Continental GT 250. Previously was a Triumph man, so I’m totally new to things RE.
It has a very bad oil leak around the pushrod tunnel joint with the cylinder head. The head gasket seems good as there is no problem with compression.
The head is the later type with the 2 allen screws adjacent to the tunnel, and a previous owner has followed what I believe to be the recommended practice of replacing the countersunk screws with cap heads. However the screw holes in the head have not been spot faced so the screw heads are fretting the head around the screw holes.
I have discovered that both screws could be unfastened quite easily. I could just try tightening the screws but I’m not sure that is the complete answer. Hence my (possibly novice) questions:
Firstly, I have a faint suspicion that the allen screws may be bottoming out the thread holes in the barrel. To fix that would it be acceptable to put some washers under the heads of the allen screws? I know this would not be ideal but it would also help stop the screws fretting the head.
Secondly, the pillar in the head where the screws go through does not seem to be very substantial to me. I’m concerned about fracturing the head at this point. I know that you cannot apply very much torque using a stock allen key as it springs, but a long reach allen socket could apply a lot more torque. But is that really advisable?
Thirdly, I don’t know if the head gasket is copper or composite. But if I have to replace the gasket is it better to use composite or copper? Also although I’m not a fan of using sealant on a cylinder head joint would something like Wellseal be advisable in this case bearing in mind the situation with the oil leak?
Sorry that my first post is so long!!
