- Fri Oct 14, 2016 8:16 am
#63290
I can't speak for the stainless 91087 silencer but do have the complete system 91130 which comprises of silencer 91080 and pipe 91085. The retort is fairly loud but by no means excessive, the note is pleasant. Neighbours have said they like it because it sounds proper. When cruising the noise is subdued, it barks when opened up, it sounds like a big single should.
The downpipe needs to be well sealed to the head (gasket 582638) or it can be very noisy. The baffles are (cof) adjustable, I have the points of the baffles about 6-8mm apart, you can push them in with a screwdriver and push them out with a steel bar. We need back pressure to provide mid-range torque, counter-intuitively closing the baffles right up makes more noise, the exhaust note gets compressed and makes loud 'bangs'.
