- Mon Oct 10, 2016 3:49 am
#6790
Iron barrel oil pumps old one stripped gear on spindle but after cleaning everything brand new one wont work can only turn less than quarter of a turn tried other used spindles spare timing cover same swapped between mr H hi cap brass pumps and original steel ones different end caps double gaskets. Spindle turns ok with no pumps, anyone had problems with odd size drive pins on spindle but cant see drive pins catching on cover plates. HELP.
