By Chug666
#6781
Hi All,
At some point in my pottering around the rural bits of Hampshire, the rubber wotsit attached to the front mudguard that holds the front disc hose in place has snapped (it was looking a bit stretched and perished so i cant say i was surprised). Is a replacement easy to source? Can't see one on here but as per previous posts my search skills have come up short in the past.
Better still, has anyone else had a similar problem and come up with an ingenious home brew solution? I have zip ties and other hoarded odds and sods at my disposal!
This is the first thing to break on my Bullet btw!
Cheers, Chug
#63102
In point of fact I do not order online from Hitchcocks, I always phone them because there are some (often major) differences with the 2011-on bikes and have found it essential to check fit.
I posted a 2010 C5 p/n but reasonably sure it will be the same as for B5 2011-on, unless RE changed the size of the hole in the mudguard - which is precisely the sort of thing they do. Do check :)
#63103
And the exploded diagrams in the Parts Books are great fro showing you where to put Loctite :)
