By simon
#13769
Ditto, my version of the repair combined with a fettling of the clutch has made all the difference so the gears change beautifully, there is absolutely no drag when stationary and in gear so that you can select neutral at any point. Makes you realize what a total cockup the bike was before the mods!
By marsie
#13831
Phil - Clutch drag. It should still clear even with the flexy cover. Adjustment Adjustment Adjustment - Buckled plates or not lifting square most likely. Thick oil in the chain case - try ATF. My classic clutch always freed, but Pete F's mod is well worthwhile.
#13832
Phil,
Marsie's right, you can adjust the clutch to work properly without this mod but there's very little leeway, especially when the clutch gets hot. The mod just gives you an easier life as you don't have to keep adjusting the cable. You still need to get the clutch operating arm in the right place and it won't compensate for warped plates or badly adjusted springs. Mine was difficult to get right from new and I was always fiddling with the adjustment - after the mod I haven't had to adjust at all and the gearbox will easily go into neutral at standstill and there's no "clunk" when engaging first (I have to free the clutch first when it's cold of course)
