- Thu Sep 08, 2016 3:01 pm
#6681
I solved my kickstarter problem, but have a lot of problems adjusting the gear change ratchet assembly.
I tried changing the position of that adjustable plate which holds the biggest spring. I can either only shift up, or not shift at all.
Right now the ratchet ring touches the inner ratchet, but does not succeed in changing gear. It slips over the inner ratchet teeth. I can also see it dislocates on the top from that spring.
I never thought I was going to run into such problems only because of a problematic kickstart pawl !
Any ideas ?
Any ideas ?
