- Thu Sep 08, 2016 3:00 pm
#6680
I am the unfortunate victim of a broken tappet cam follower on an eight year old Electra - quite a tragic occurrence, timing side and inlet valve trashed.
But I think it was caused by using the valve lifter to stop the engine. I was advised to use the lifter after my sprag clutch failed due to kickbacks and I did that for a year or so and then bang, timing all wrecked. I also wonder that the setting on my lifter is very high and that it allows the cam to strike the tappet with some force when in use and possibly fatiguing the cam follower causing the catastrophic failure of the cam follower head.
I have repaired the bike and now I am concerned it will happen again. I will obviously not be using the valve lifter to stop the engine but I still prefer to use it to start the engine to avoid kickback risks so I have set it to only just lift the valve ( It only needs to lift th exhaust valve a fraction to work)
Does anyone have any further advice about adjusting the valve lifter to prevent the damage? Or just remove the lifter altogether?
