- Tue Sep 06, 2016 10:39 am
#6676
Perhaps some of you can help with filling in some gaps in a conversation I had with the mechanic servicing my bike? I was having a front fork sorted under warranty (see the diatribe on 'pinch bolts' somewhere in the archive). Anyway, said fork was replaced, and the mechanic said that everything was fine, there was just a bit of a rattle in the engine. Now I've never noticed a rattle in the engine beyond what might be normally described as 'oh they just do that' or 'it's character', but as he mentioned it I started worrying. Initially he asked if I had "ever revved it from cold?" Now, I'm a sedate sort of person, and I don't recall ever revving it, from cold or indeed at any other temperature. He then continued "you know you've got hydraulic tappets?" I nodded wisely - this much I did know. "Well..." he continued "sometimes you get a little bit of oil in the xxxx..." Now at this point, I confess that my attention drifted. This was partly because I was trying to recall what I knew abut hydraulic tappets so that I didn't appear to be a total numpty, but mostly because a rather attractive young lady happened to be walking past at that precise moment wearing a skirt just the right side of decent. He continued "it's an easy job, you just remove the xxx cover and push hard down on the xxx and you'll see the oil come out and it'll be fine." Then he added "job's a good 'un" for good measure. I should of course have asked him to repeat it so that I actually knew what he was talking about, but my 'don't look like a total idiot' protection mechanism kicked in and I didn't. I just rode off with the rattle that I hadn't noticed before but which now worried me. If I had to specify what the rattle was, it seems to come from the general area of the rocker cover and to only be there when accelerating.
