Plugs out and keep kicking unless you have starter rollers. I usually start priming with 50 kicks at a time long before I'm ready for a full start, I just treat it as a cheap gym membership! You should have used plenty of oil in the various obvious places when you rebuilt it but also tip plenty down the pushrod tunnels (via the rockers,) to stimulate the return pump. When you start it run it with the oil cap off to see the return flow, this will take what seems like a worryingly long time even if all is well! You can also leave a rocker feed bolt loose to check flow there. Be careful when inspecting the return in the oil tank, it can suddenly spurt (oooh missus) at high pressure and cover you....
