By Martin - Wed Jun 20, 2012 3:46 am
#658
On early 500 twins, the Lucas generator
and coil ignition distributor is one unit.
Replaced brushes, and new bearings, field
coils seem OK, but did not have buzzer to
throughly check the armature.
Anyway, minimal output with 1000rpm drill
attached, either .375V, or 3.75V. Took it
a starter/alternator repair shop with the
zeroxed spec. sheets, but they had never
seen such archaic artifacts, and merely
annouced it didn't 'produce'..GEEZ,I know
that already..
Someone suggested just ride it without
any current, and am sure to have done that
long ago with defunct Magdynos. So, aside
from discreet use of the stop light, how
long can get from a fully charged medium
'bike battery with just coil ignition...
or what is the actual amperage drain?
Am overseas, and already know this unit
is only fitted to the Square Four. Weight
is too heavy for posting, so a summer time
comprimise.
Thank you!
that already..
comprimise.
Thank you!
