- Wed Aug 31, 2016 5:54 pm
#6649
Good day all,currently I am experiencing somewhat of an attainable
challenge.I have been comforted by the fact that this forum's
talents and expertise is leading me to a positive outcome.I am drawn now to at least reciprocate the good nature of this forum by expressing some points that may be helpful.
# Early type distributor with the greasing point,overgreasing can have the effect of dislodging the shaft seal causing excessive grease into the points plate assembly area and disrupting the plate mechanism.
# Distributor shaft end float,depending on the actual float(in&out),
may contact the rear of the cam/points plate assembly. Again the
potential effect is self explanatory.In my case with the Boyer fitted
and end float approx. 2-3mm, the rotor plate had just started to scuff
the solder joints of the rear of the stator/coil plate.
At this stage, I believe shimming the shaft is an option,my next
mission is to find out the correct and practical method.
I hope this helps,by the way my experience with the RE is somewhat
limited,yet again I find it quite refreshing of the value of this
particular fraternity and sorority forum.
All the best....Cheers
