- Tue Aug 30, 2016 4:21 am
#61897
Exile I have followed your advice as well as Pauls earlier help.May I say I haven't been totally honest with you.I am somewhat of a novice with this
procedure of timing/marks.Your combined steps to fit the boyer had and has
been repeatedly followed.May I trespass on your patience, perhaps the forum
community and your own experiences may pick up on my failures for correction.
Timing marks: On an old disused CD, I think it may have been an Indian production, the title may have been,"How to make your RE to Indian standards in ten easy steps."Funny about that it only ran for a few minutes.In any case on the CD I marked a line from the centre straight up 0 deg to the CD's periphery this I called TDC then 28 deg left of the TDC line I marked a line from the CD centre to its periphery this I called BTDC.Protractor was used degrees are spot on.I then drilled a hole in each of these lines to enable future marks to be painted on the stator(TDC) and the rotor(BTDC)Then I carefully enlarged the bore of the CD 2-3 mm more to enable a tight fit on the rotor nut, concentric bore maintained.TDC on the compression stroke using the Fred Flinstone method that is a piece of fencing wire,4th gear turn back wheel wire up and down in the spark plug hole straight up and down till without a doubt TDC of the engine found.Stay with me now people.Marked CD placed on rotor nut,TDC line White permanent marker through
the hole to mark the stator .The BTDC line hole, marked the rotor.TDC engine
maintained ,Boyer set up as per your efforts all good.Spark plug reinstated
gear neutral,ignition, starts, timing light on alternator marks,rev, marks are misaligned,turn Boyer stator coil plate,marks move towards alignment not
enough however.The plate has reached its limit of movement Feel free to
educate me. Exile I appreciate your efforts through your example of expressing joy by raising your hands high and running around your shed as you had mentioned.Alas I have not reached that standard,currently I am approaching the pulling my hair out,that is singular as opposed to hairs plural. All the best people....Cheers.
