- Sun Aug 28, 2016 11:52 am
#6639
Hi folks. Still sorting out Rusty, my 350 Superstar. The head has been ported by BW, I'm running an 8:1 piston and it has a Mikcarb 28mm (500 Bullet size). Pretty much run in now so starting to open him up a bit. Goes well! Carburation is ok, but I think I need a different plug. I'm running the standard NGK BH7HS, and the insulator is a bit too white for my liking, and when I turn off the ignition I get some running-on, which I think is because the plug is running hot.
Which way do I go - I get confused by terms like 'hotter plug' and 'cooler plug' and don't know which grade to go for. Any help gratefully received!
Thanks
Stephen
Thanks
Stephen
Regards
Stephen
250 pre-unit Clipper
350 Indian Bullet Superstar
535 Bulsader
700 Conny
New 650 Interceptor
Stephen
535 Bulsader
700 Conny
New 650 Interceptor
