- Thu Mar 16, 2017 3:49 pm
#66536
Mauri My engine is now finished but The box mods are still to do. When I cut down the gear shaft are the cut points exactly where the shaft changes diameter to get the correct bar length either side? I plan to leave a bit extra to turn a peg to center in a hole on the other end to centralise before welding.
I'm also a bit worried about boring the cover in the right place. By painting the gear shaft and poking it in reverse though the bush to hit the cover back I have a center point but it's not really very accurate? How did you find the center to drill the cover and get it central to the old bush?
I have bought a new oil seal and Bush to fit the cover hole but how did you fit them? Did you fit in the inside of the cover or from the outside if using a double ended gear shaft? Any more diagrams would be great.
