devon john
im talking about these studs, as far as i know there are imperial up an till the electra!
ginetta lad
thats because you don’t need that kit, unless you like to spend money for nothing.
the indian reseller i bought mine of did the mod for me at the time with no extra cost.
unfortunately this seller isn’t active any more.
since then i have don a couple myself, and is pretty easy.
the only parts you need to order are these, the first two can even be found pretty much any where(washer, m5 nylon nut).
all that remains to do is, get a plug made to close the rear hole, you can ever re-use the bushing and seal you removed from the gearbox to put the plug in.
get the cover bored out to take the bushing and seal you have removed from the gearbox, shorten the gear lever shaft and thats it.
i get the labor done at my local shop for €40,00 with is way cheaper than £210,00
the assembly i do myself.
don’t forget that hitchcock is like any commercial business, they make stuff for you to buy.
some of these thing are made for ease of mounting, but don’t necessarily have your best interest(wallet) in mind.
you and you alone have to decide if you go the easy way and spend the money for it.
or you can use your imagination and wit and come out richer in many ways in the end
