- Sat Jun 16, 2012 9:28 pm
#641
I am aware that, despite identical part numbers for the driveside mainshafts, there is a variance in the fit of the splines of an electric start engine sprocket versus a kickstart-only sprocket. My bike started life as an electric start (Sixty5) which I converted to kickstart-only, but the new KS engine sprocket was a sloppy fit on the splines (unlike the original ES sprocket, which was snug) but I used it nevertheless for a few thousand miles. However, now that I am doing a major rebuild, I want to put this right. One option that I have heard of, is to have the starter gear removed from my original ES sprocket. That would be the perfect solution, but since it is hardened steel, it would be a specialist job (ie. surface grinder or special cutting tool?). Or is there possibly a kickstart engine sprocket available which would fit more snuggly? Has anyone successfully overcome this problem, or can anyone recommend a capable machine shop for removing the starter gear of my original sprocket? Cheers!
