- Fri Jul 15, 2016 3:51 pm
#60249
I know the ElectraX doesn't have the decompressor, which is why I was careful to put "C5" into the description. However it only has 7.5:1 compression and with the starter/battery in good order should be able to spin that. It is where the starter doesn't get enough urge that the motor can kick back, which is what damages the sprag; likewise a half-hearted prod of the button, the starter has a half-go and gets kicked back and the sooner or later the sprag is damaged; the starter needs to keep its force on the sprag against the motor to prevent that, it has to keep the sprag engaged, if you release the button too soon the sprag releases and the motor can come back on it like a big hammer. If you've ever kicked a goldie, you know you have to 'go through' or it will bite back. The problem is far from unique to RE, it's actually a poor engineering design but everyone has copied it.
