Puncher!
Posted: Tue Jul 05, 2016 10:02 pm
Good evening all,
I was on my daily commute to work this morning and when in the grounds
I'm met by a row of speed bumps. And after the last bump I noticed a bit
Of movement from the rear and that's when I noticed the flat so with only
a 100 or so meters away I continued to park up and go to work with the
thought of inspecting at my lunch break (1hr)
Upon pumping up I notice a hissing so I quickly got some washing up liquid
And a bowl of water from the kitchen and began to locate the leak which turns
Out to be around the valve. Upon inspection I noticed the valve was loose and
Spinning freely so I had a look inside the tyre as ther was no air present .
The valve look like it use to be from a inner tube and has been used in the
Rear wheel to inflate.
So the question. Is the tyre TUBLESS because that what it says on the tyre
Or dowse it have an inner tube?
The bike is a RE Electra on a 10 plate and the tyres are the Avon standard
Fitted ones.
Fitted ones.
