- Tue Jun 21, 2016 2:58 pm
#6399
After trying to guess what 0.8mm / 1/32", is for years, I decided to buy a deg. wheel kit from our Host. Got the piston to TDC & the deg. wheel set to 0 deg. Then the question was how many deg. should it fire BFTDC ? The workshop manual only shows everything as 0.8mm / 1/32".
Please may I ask if someone could tell me how many deg. BFTDC should the points open? for static timing.
And also how many degs, should the auto advance bring in, when checking with a strobe light/ Thank you in advance Martin
