efi 2009 kickstart fit
Posted: Mon Jun 20, 2016 10:48 am
by jonny
Hello . Is there a kit available to put a kickstart on this bike,as you all know this is handy, to give the e/s a rest and for setting issues, is this going to be a expensive add on . Thanks
Posted: Mon Jun 20, 2016 7:33 pm
by CGT 535
I don't know if there's a kit available, but looking through the on-line parts books I've got the cost up to £312.96 (inc vat) which gets you a R/H engine cover, kickstart and the kickstart shaft sub assembly. On top of those items you'd also need gaskets and seals etc. I'm starting to think it's going to be expensive (I also have an electric start only Electra EFI). There again, you only need to trash a couple of sprag clutches to spend more than £312!
Posted: Mon Jun 27, 2016 1:02 pm
by jonny
Hello .Thanks for the info,if i was to pursue this conversion is it a complete engine strip down, or can you gain access to the side of gearbox to fit the parts .Thanks again
Posted: Mon Jun 27, 2016 3:52 pm
If you look carefully at the parts diagrams you should be able to see what parts you need. I think your going to find it all comes down to whether the gearbox main shaft is different. The outer case is around £160 and you'll need this unless you can get the original machined (supposing it is the same apart from the blanked off bit) If you need the mainshaft as well??
A lot of these early EFIs were recalled for a gearbox problem; I would try to find someone who did some of this work (did they all go back to Watsonian?
Posted: Mon Jun 27, 2016 4:09 pm
by papasmurf
Details of recall here:-
http://www.dft.gov.uk/vosa/apps/recalls ... =Blank&tx=
Vehicle Details
Reference : RM/2009/019
Manufacturer Ref :
Make: ROYAL ENFIELD
Model : Bullet Electra EFI and Bullet Classic EFI
Launch Date : 19/06/2009
Numbers Involved : 258
Build Start Date : 01/09/2008
Build End Date : 31/03/2009
Recall Details
Concern : REAR WHEEL MAY LOCK
Description : It has been identified that due to oil starvation caused by incorrect tolerances, third gear may seize on the gear box main shaft. Should this occur the possibility exists that the rear wheel could lock whilst the machine was being ridden.
Remedial Action : Recalled machines will have 3rd and 4th gears replaced, additionally the gearbox main shaft.
Vehicle Id :
Other Vehicles Affected (Click the vehicle to perform an extended search)
•ROYAL ENFIELD - BULLET
