- Tue Jun 07, 2016 3:55 pm
#6350
Hello Comrades
I am about to Change the Disk Pads on a Electra X Type Unit ( and Clean the pistons up a Bit) .But cannot spot much info on them.
*Once having swung out the whole caliper unit,
I presume you just remove the :PIN BOLTS part 560594 and the Pads Drop out??
Am I right?? And is they anything unexpected to look out for? (Different to other Disk set ups)
Thanks for any Help or Advice… Cheers All Craig
Caliper Assembly
Caliper Assembly
