- Tue May 17, 2016 2:34 am
#6271
I'm restoring a 1995 500. I disassembled the distributor to clean it out and re-grease. I can't get the cb/timing pinion gear (from the timing cover side) fixed back on the taper of the cb shaft. All the direction I've been able to find says just "give it a smart rap with a hammer". I don't want to hit the gear with a hammer, nor the points plate or cam/governor assembly. There is also about 1/4 inch play/movement of the shaft inside the distributor body, which would make striking ineffective. I can't use the pinion nut to force them together, since the shaft turns. Any suggestions?
Thanks.
Thanks.
