- Wed Apr 13, 2016 6:47 pm
#6161
Hi all, fitted my newly purchased PCV on Sunday and took it for a run. Worked fine for 10miles ish then started miss firing and popping. Changed plug as this was old one and seemed ok. Went to start this morning and would not start on the electronic ignition but it did eventually kick started it. Rode to work ok but had little power and kept popping and banging. Went to leave work and would not start either kick or switch. Has anybody experienced this with PCV?
I've checked the connections , got good spark too. Crank position sensor Mayb? Need some help !!
Thanks
Thanks
