- Mon Mar 14, 2016 6:51 pm
#6041
Before I go tearing into the wrong area, perhaps the forums combined knowledge can help. On starting my 05 bullet after the winter lay-up I noticed the ammeter didn't move from central position when I used the kick-start. I thought the battery was flat but after three or four kicks the engine started OK and off I went for a ride, during which the bike ran perfectly. However, after being idle for half an hour, I had a huge problem trying to restart it. Again the ammeter was only showing discharge after several revs of crankshaft on the kick-start. The bike is fitted work Eureka electronic ignition. Finally it started after twenty or more attempts. Ammeter shows a little charge when normal riding, as you would expect. Any thoughts lads?
